Kearny Tracker 2HL age and best way to lift? - Page 3
Page 3 of 3 FirstFirst 123
Results 41 to 46 of 46
  1. #41
    Aug 2003
    port allen, louisiana usa
    1,638
    428
    374
    On the lugs, maybe you can drill and tap for a socket head screw on each side..Is the gear hardened? File hard? Find a socket head screw that is close to the slot size in the spindle or maybe that can be machined to fit...... Kinda like Keith Fenner has on the spindle of his 2hl but in reverse...Just a thought.. Cheers; Ramsay 1
  2. #42
    May 2009
    172
    31
    19
    Got brave last night while continuing the cleaning. I was working the power feeds in each axis and crept up on the limit stops to see if they worked correctly. Other than cleaning out some lesser used sections of travel which were sticky, it's doing its job just fine to keep me from crashing into the hard stops.
    I also stuck my hands as far as I could into the coolant sump and stirred the muck, not a pleasant place, but not foul like when I scrubbed out the one in my current lathe. That one reeked to high heaven and I had to use a concentrated water soluble cleaner that was made to kill the bacterial growth. It took days to finally kill the stench. Not an experience I would care to repeat.
    Mark
    Sent from my ONEPLUS A6013 using Tapatalk
  3. #43
    Aug 2003
    1,638
    428
    374
    Quote Originally Posted by Crank View Post
    Mark
    Light bodied cutting oil for the coolant sump of your K&T after all the dead animals are retrieved and sump sanitized and put the stink factor to rest forever... Just add oil every few years as the level drops... Ramsay 1
  4. Likes Ohio Mike liked this post
  5. #44
    May 2009
    172
    31
    19
    Redecorating!
  6. #45
    May 2009
    172
    31
    19
    Now to fill in all of the empty spaces with the rest of the stuff I moved into the driveway. Don't worry, I'll have everything leveled before I do.
    Mark
    P.S. May be obvious to many, but I had no idea the solvent resistant layer of scum on my Bridgeport was actually fossilized water based coolant. For years I was puzzled why it was impossible to get it clean. Today, about an hour and a bucket of soapy water and it looks pretty good now
  7. #46
    Aug 2003
    1,638
    428
    374
    Wow mine use to be clean like that once upon a time.. Oil will stain your paint as well....Funny ... When you get them all cleaned up, they look really nice. Somewhat of a shame to use them and get them dirty again.. Ramsay 1
