stoneaxe
Stainless
- Mar 2, 2010
- pacific northwest
So along with the positioning question I have been spewing forth, I have another-
The VN spindle seems to have about .0005- .001 runout, measured on a 1/2" ground shaft inserted into a collet. The measurement is taken an inch down from the collet.
When I got this machine, the spindle had a bunch of built up material in the taper, like would result from spinning an unhardened collet or holder. So I used a steel scraper and got it out.
Any collet or end mill holder used in the spindle ends up with a ring of "fretting" marks around the taper , about an 1/8" wide and located close to the small end of the taper. This wear cannot be felt with a fingernail. Nor can any burrs etc be felt in the spindle taper.
I am thinking about making a brass lap, with the VN taper, and using a fine diamond compound to very gently lap the spindle, checking with bluing and a new collet. The object to remove any tiny high spots left on the taper ID.
Is this nuts?
Is this nuts?
