Late square head Pacemaker- Where is the headstock oil pump?
Likes Likes:  0
Results 1 to 4 of 4
    Oct 2009
    Oregon
    4,590
    4949
    2378
    Default Late square head Pacemaker- Where is the headstock oil pump?
    My 14" Pacemaker is slow to pump oil and doesn't flow much. Anyone know where the pump is? I'd like to check the pickup and wouldn't surprise me if it needs rebuilt.
    Jul 2004
    Houston, TX USA
    30,479
    On the end of input shaft on the earlier ones - right where it needs to be. When the input shaft is running (clutch engaged), so is the oil pump
    Bulletin 20 for what its worth - thanks to Greg Menke for hosting this for me
    http://pounceatron.dreamhosters.com/...in-20-1966.pdf
    ph
    Oct 2009
    Oregon
    4,590
    4949
    2378
    Thanks John. Probably safe to assume it's in the same location on the square heads I suppose?
    No problem pulling cover if that's it. Just didn't want to pull it off to find it was down in the bottom somewhere.
    Jul 2004
    Houston, TX USA
    30,479
    Quote Originally Posted by Garwood View Post
    Seem reasonable to me. Here is a later job - at least some tray removal to see pump
