Leblond Regal 15x30
Likes Likes:  0
Results 1 to 6 of 6
    Dec 2018
    33
    Default Leblond Regal 15x30
    Can anyone shed some light as to the age of this machine? Any features that are desirable or undesirable compared to other models/years? I'm told it was used in a university setting and the ways are "like new." It comes with a Hardinge collet chuck, and a new import 3 jaw, but not much else. No steady, follow, taper attachment, etc... It's a 3hp 3ph unit, and I think it's just about the ideal machine for my space (garage shop so power and space start becoming issues if I go any larger). Should I jump on it if the condition is as he says? Or should I hold out for a better model?
    Feb 2005
    Ohio
    1,183
    1282
    205
    Circa 1955~1960 Regal... the rounded top on the tailstock housing and legs that angle inward then out at the very bottom are the identifiers.
    Machine tools from a school setting typically have had minimal use and minimal care or maintenance.
    Mike
    Dec 2018
    33
    Is that better than heavy, well maintained use?
    Jan 2009
    Maine, USA
    176
    87
    82
    For a machine that age I'd say it depends but this machine looks pretty good to me. You see tons of these things sitting in a barn or outside covered in rust which makes it hard to even do a good inspection. This one looks like you could go right to work on it. For me it'd definitely be in the running for a great home shop machine if the price was right (what is the price BTW)? Check all spindle speeds, open the headstock and take a peak, inspect ways, inspect lead screw, and take it home... Gear drive, likely pretty stout, enclosed QCGB, 3hp is perfect for home shop. If it takes change gears are they present?
    Dec 2018
    33
    Quote Originally Posted by JCByrd24 View Post
    Price is $2850, and doesn't sound negotiable.
    It was confirmed on another forum there are no change gears required, beyond transposing to metric.
    Jan 2009
    Maine, USA
    176
    87
    82
    He knows what he has then. To me it's a good price for the machine in good running condition in my mind. If it's powered and you can see it run in all gears and have him do a test cut I would take it for the asking price. Love to have it in my shop.
    Edit: I see there is much more discussion at the HSM site... 5 hour drive for this one makes it much trickier to evaluate all of the above. No steady isn't a deal breaker to me as it is for some, easy enough to build.
