BoxcarPete
Stainless
- Nov 30, 2018
- Michigan, USA
I have a 19" LeBlond Regal (1967 vintage) with a puzzling issue on the feeds. I was wondering why I kept favoring feeds much lower than what my brain tells me is appropriate and I decided to do some sleuthing.
Set up a bar in the chuck and made a nice little spiral around it with the leadscrew at a couple different TPI. They all checked out OK per the feed rate chart on the headstock. Then I engaged the cross slide feed, and what should have been 0.0172 IPR (cross-listed with 12 TPI) fed the carriage about 0.045" after rotating the head one revolution. I thought about needing to divide by 2 to get the actual size since it's listed diametrically on the cross slide, but that is still not correct. It's a factor of 2.6 off.
It makes me wonder if the lathe was changed to metric feeds or something, but it's very puzzling because the leadscrew still feeds TPI and that's what you'd really want to change if you needed metric.
Anyone know what might be going on here?
