Cincinnati No. 2 horiz plain crank and ball handles, source?
Cannonmn
Stainless
Jun 25, 2016
Need source for 755CE8E3-718E-4864-A0E6-D06BA5EFDE81.jpg755CE8E3-718E-4864-A0E6-D06BA5EFDE81.jpg755CE8E3-718E-4864-A0E6-D06BA5EFDE81.jpg755CE8E3-718E-4864-A0E6-D06BA5EFDE81.jpga few black plastic ball handles with female threaded steel mating insert. Also need one crank for the two crank sockets on left lower part of mill, as shown,in pic.
Donor mill or make them on the crank. Example thumbnails
Say thread requirement for the KNOBS and I will see what is in the collection - which are all black and plastic - with metallic inserts for threads
John, if you have dozens with various dia/pitch fem fittings, sure I’d be selective, can get meas. Tomorrow. If u have 6 knobs only, with different mating holes, I’d gladly adapt all non-fitting ones. Anyway I’ll measure tomorrow and post results.
Need source for a few black plastic ball handles with female threaded steel mating insert. Also need one crank for the two crank sockets on left lower part of mill, as shown,in pic.
John,
Probably, the threaded insert should not be a strict requirement. I have several machines with plastic thread that survived undamaged half a century or more of abuse.
If John Oder fails to find what you want among his collection, McMaster-Carr has a good selection of new ones and they're fairly cheap: McMaster-Carr
Paolo
3/8-24 is the way the levers needing knobs are threaded. I need three only at this time but would take 4 to have a spare if you have enuf.
I'll crawl up in the barn and see what's there
On Edit
4 ea NOS in BLACK plastiic with steel 3/8-24 insert - which shows some rust. Probably need to run in a tap to clean them up
These are 2" balls - may look a little clunky on a #2 mill
Too fat for for SFR box, so you get to pay for a medium
PM a mailing address if wanted
You get to decide if they are worth more than the cost to ship them
I see McMaster Carr has a broad choice of them for very little $ each
