Lodge and Shipley 16" questions
Vbmatc1776
Aug 25, 2019
Hello I was hoping to pick your collective brains for a moment:
I bought this machine at auction a couple weeks ago. I think it's a 1953 model x by lodge and Shipley. I could use some more information on the machine.
What kind of oil should I be using for the spindle and head gears? I found that I should be using vactra #2 for the ways. But didn't find anymore info
I would also appreciate any information that anyone might have on sprucing her up. Any tips or tricks to get the lathe running tighter tolerances would be awesome. I realize I'm not going to get a 70 year old lathe to run tolerances of +/- .0001.
But I'd like to get it running as tight/true as I can.
I'm not new to machining but I'm definitely new to machines this old. I have run lathes and Mills that were made in the 80's or after but nothing from the 50's. Any info on running machines of the era , or info on reconditioning old machine tools would be greatly appreciated.
For example: there is no dial or vernier scale on the z axis . Why is that? Is that a damage/modification the happened to the machine before I got it? Or did old-school machinists just use dial indicators/gages for everything ?
Thanks for your help.
Have a good one
Link to pictures of the machine:
Lodge and Shipley 16" - Album on Imgur
Whoa, dial for Z? I've never had a lathe with graduated movement along the ways. That's what created a market for the Trav-A-Dial company. For short movements, many of the old lathes may have had a mechanical stop with a graduated adjustment that could be mounted anywhere along the ways, but long travel was just a ruler and a tweak.
Good looking machine there, by the way.
It would not know what a Z axis was if you asked it. No such thing when it was made in the fifties
Its top end will be either 1160, 1740 or 2000 (and HP will be 10, 15 or 20)
ISO 46 (such as DTE medium) for 1160, lighter as you go up on top end - depending on how much the upper ranges are used
All oil is in sump low on rear - oil pump HAS to be working
Probably need hearing protection in a small confined shop - they are noise makers
Manuals compliments of VM
http://vintagemachinery.org/pubs/2104/18295.pdf
http://vintagemachinery.org/pubs/2104/3561.pdf
Serial will be right end on top IN BETWEEN TWO REAR VEE WAYS if you want it dated
Looks like so inside
Having a dial on the lathe long travel hand wheel is reasonably common over here, I've worked on a few both large and small. Normally they won't get you much nearer than 1/16" so they're not in the " Trav-A-Dial " league for accuracy but they're better than nothing.
Regards Tyrone.
