Milacron Monoset Chamfer Reamer
I want grind straight/spiral chamfer reamer
Any infos, step by step...Please help
What is a chamfer reamer? You mean the chamfer on the end, or...??
Not sure why you want to make your own when they are readily available for purchase, and not overly expensive unless you get into very large sizes or solid carbide.
McMaster-Carr
https://www.mscdirect.com/browse/lookahead/?searchterm=reamers&hdrsrh=true
Reamers and Reaming Tools - Grainger Industrial Supply
I want to learn on Monoset, I want to regrind chamfer on straight/spiral reamer (6 to 8 flutes), i need help how to setup and grind...
Thank you.
The Monoset can run a spiral flute.. a thing that a #2 can't do.. but as far as most cutter grinding the Cincinnati #2 or #1 book/operators manual gives more cutter grinding information. Much that can be also used on the Monoset.
I recommend using that manual along with any TC grinding...
Yes the radius gerinding feature of the Monoset is a plus for the Monoset..but the #2 book information can also be helpful for that.
The Monoset is a great machine ..but its manual is poor IMHO.
