Pratt & Whitney 12 x 30 Model C - Removing apron front
Page 1 of 3 123 LastLast
Results 1 to 20 of 41
    Jan 2016
    Vermont
    17
    Default Pratt & Whitney 12 x 30 Model C - Removing apron front
    I am in the process of refurbishing my 1957 P&W 12x30 Model C lathe and need some help/advise on removing the front of the apron. The brochure says it's EASILY removable but mine seems to be hung up somewhere. I have removed the 9 cap screws, all the handles,and the set screw holding the threading dial. Any shaft going through the front casting looks like it should slip through. I've gone as far as driving oak wedges between the front and back casting and have driven them apart about 3/16" all around. I'm afraid to drive them further for fear of cracking the front casting although so far everything about this machine impresses me as far as beefiness. If anyone has removed the front apron on their lathe I would appreciate any help you might offer. I will try to attach some pictures.
    Attached Thumbnails Attached Thumbnails img_0910.jpg   img_0911.jpg   img_0912.jpg   img_0913.jpg
    Jul 2004
    Houston, TX USA
    32,126
    Might be helpful
    Jul 2011
    Oregon
    478
    126
    288
    I think you are catching on the interlock rod that keeps the thread lever from being engaged while the feed lever is engaged or the other way around. If you look just the right on the longitudinal feed lever and also just to the right of where the thread engagement lever is there are two shafts sticking through the casting. Each has a set screw that locks them in place. You need to remove the set screw in each and tap the shafts towards the back of the cover.....
    Jul 2011
    Oregon
    478
    126
    288
    You may have already bent the rod with your wedging. It is pretty small diameter. Let me know if that works. Do you have the manual? Good drawings in there.... I think I have a pdf somewhere.
    Jul 2005
    Cottage Grove, MN 55016
    8,414
    4414
    4935
    I would screw in some long Allen cap screws so the cover hangs on them. Then see what happens. Then I would drill / tap the dowel pins and see if you can lower the cover. I'll do some research and add more. Rich
    I found this manual: http://neme-s.org/Shaper%20Books/Pra...WModCParts.pdf
    Figure 18 & 19...I would remove the star nut on shaft 27 and the thread dial 17 on figure 19 and see what happens.
    Jul 2011
    Oregon
    478
    126
    288
    Thanks Richard for finding that. If you look at section GG figure 19 you can see the interlock rod I mentioned and why it won't come out with that in place. I do think Richard is right and the nut he mentioned should come of as well as the thread dial itself by loosening the set screw on the side of it.
    Jan 2016
    Vermont
    17
    PMtool - Your suggestion was spot on. I removed the wedges to relieve the tension, removed the two set screws and tapped in the shafts. After that things loosened up with a little tapping and the apron front came off.Luckily the small rod wasn't bent. Originally I had removed those screws but replaced them as the diagram in the pdf brochure I downloaded, showed them attached to the cover. I think if the clutches had been in just the right orientation the rod would not have hung up. I hope this is a correct assumption because it's going to be a bear reassembling the cover while getting the rod shafts into the cover. Thanks again for you help and the other contributors suggestions.
    Jul 2004
    Houston, TX USA
    32,126
    If you need the op manual pdf just private message me your EMAIL address
    Jan 2016
    Vermont
    17
    John, thanks for your offer of the op manual. I was fortunate enough to get the original manual that came with the lathe. I also have a copy of the parts list which I may have downloaded from one of your earlier posts. Related to this same subject do you know if there exists manuals on the disassembly and assembly of this lathe?
    Thanks, Richard
    Jul 2004
    Houston, TX USA
    32,126
    Highly doubtful. In a bit less than fifty years of old machine tool pub collecting, I have never seen or heard of such for this make. Only make known to me that provided such was Cincinnati Milling Machine
    There is an excellent reason for this in the case of P&W. For a very long time - if your P&W needed working on, you just telegraphed (or later telephoned) and a factory service tech would be at the train station by and by.
    The P&W parts books/manuals - especially the older ones - are lavishly and competently illustrated
    Quote Originally Posted by greenmtfan View Post
    Thanks, Richard
  11. #11
    May 2013
    Shasta County, Ca. USA
    1,017
    92
    255
    I am really curious how this procedure worked out for putting the cover back on. I have this chore coming up soon. I looked at the interlock assembly on my Model C and I see no way that the cover can go back on the apron unless the interlock assembly is installed beforehand.
    I can envision a tool possibly to spring the interlock shaft towards the tailstock side enough to let it slip over the feed clutch drum.
    When I pulled it off I experienced the same hang up and I believe because the half nuts were not engaged mine actually was able to spring to clear the feed clutch drum.
    I dread reassembly based on the fact the bevel on the interlock shaft is on the opposite side of the clutch drum.
    Anyone out there put one back on?
    I agree with John above that Pratt and Whitney went above and beyond with illustrations. I recently was involved repairing an American Lathe from the late 60s and the parts manuals etc. were not the greatest and in some cases left most of the details up to you to stumble on for yourself. Apparently American changed things up from year to year and it is hard to come up with an exact parts manual.
    The original parts manual I have is a work of art for my 44 Model C. Such a pleasure to see such quality especially in our modern days.
  12. #12
    May 2013
    1,017
    92
    255
    Hopefully there is someone out there who has reassembled the apron cover and not just those of us who have only taken one off.
    I will post my results for the solution when I get that far.
  13. #13
    May 2013
    1,017
    92
    255
    Still hoping someone has put one of these back together and chimes in.
  14. #14
    Jan 2016
    Vermont
    17
    I'm in the same position as apparently everyone else. I'm still in the take-apart stage and although the apron front is restored, I'm working on the apron so haven't got to the reassembly stage yet. I will be following this thread like the others to see if anyone finds a solution and will be sure to post one if I figure it out. Right now I'm having a problem removing the two feed clutches. Anyone removed them and how?
  15. #15
    May 2013
    1,017
    92
    255
    Big nut on back of apron holds the feed clutches. As I recall certain gears need to be removed simultaneously on the apron feed side. I remember driving the clutch units out from behind with a brass drift.
  16. #16
    Jan 2016
    Vermont
    17
    Thanks conant. I came to the same conclusion. I'm using an oak 1/2" dowel. When I drive the dowel from the back the front part of the clutch is separating from the back like it's a press fit. This is confusing because it seems like this should be a slip fit to allow the two faces to lock when the handle is engaged. I guess I'll figure it out when I get it separated cleaned and reassembled. Thanks again for your help.
  17. #17
    May 2013
    1,017
    92
    255
    Help me remember here. Does the worm gear have to be removed first before the clutch units.
    It is a fixed shaft and the clutching function is a matter of hubs engaging the gear.
  18. #18
    May 2013
    1,017
    92
    255
    If you look closely at the pdf that Richard King posted near the top here you will find the diagram showing the feed units.
    After looking closely I see now that the radius in the worm and mating worm gear require removal of the worm before the clutches.
    I do remember that the oil pump needs to be removed so that the worm can pass to the tailstock end and be removed.
  19. #19
    Jan 2016
    Vermont
    17
    I was afraid of that. Hoping I didn't have to mess with the oil pump and oil feed tubing lines. I hope I didn't get this posting to far off topic from my original inquiry. Thanks again, conant for your info.
  20. #20
    May 2013
    1,017
    92
    255
    I don't see it being too far off topic. Reason being is there are few out there who have any information on these machines. I scour this forum searching Pratt and Whitney lathe on a regular basis.
    I appreciate finding anything I can.
    The apron and related feed rods and screw are a hand full
