Cal Haines
- Sep 19, 2002
- Tucson, AZ
A question for johnoder or anyone else with serial number books that cover pre-WWII milling machines:
In the late 1930s, Van Norman switched to 4-digit serial numbers issued sequentially by model number; that is, all the No. 12 milling machines started getting a serial numbers starting at 5000; No. 26's also got serial numbers starting at 5000. The full serial number of the machine was the 4-digit number with the model number as either prefix or a suffix (i.e. 5000-12, 7689-12, 5000-26). Prior to that, Van Norman appears to have used 4- then 5-digit serial numbers assigned sequentially to milling machines regardless of model. The 5-digit numbers went at least as high as 13744 before the switch.
Does anyone have any serial number reference books that cover the period prior to 1937?
Thanks!
Cal
Thanks!
Cal
