Gotta replace the Bearings from the Feed Drive on Van Norman 22L. How do I remove this plug from the back of the knee?
Apparently the main shaft with the Cam (the one you see in the photo) needs a bearing replaced as well (it was a Federal 1205, I believe it's comparable to a 6205),
BUT, that's not why I pulled the knee. The shaft that drives the Main Feed pinion needs a bearing replaced as well, but it's behind the plug to the Left.
How can I get that out? There's no screws, but it's obviously a plug. Kinda soft. I could dent it if I hammered on it (prefer not to until I know what's going on with it though).
Behind it sits the Main Feed Drive Bevel Gear and Pinion. The pinion can be seen peeking out from behind the main shaft in the second photo.
Anybody have experience with it (or something similar)?
Thanks!
Thanks!
