Specifications for 2H High Speed Universal Vertical Head Drive Gear
Results 1 to 4 of 4
    Nov 2016
    Michigan
    30
    Default Specifications for 2H High Speed Universal Vertical Head Drive Gear
    I’m trying to find:
    1. Diameter of drive gear.
    2. Number of teeth on drive gear.
    3. Diameter/thickness of spacer ring.
    Thanks, Greg.
    Aug 2003
    port allen, louisiana usa
    1,573
    382
    338
    Default 2h drive gear for std hi speed head per John Oder from a previous post.. Thanks John!
    Quote Originally Posted by gregfortin View Post
    I’m trying to find:
    Thanks, Greg.
    Mike G. (Ramsay1) was kind enough to share the "spacing disc" diameters on his 24 and 30 tooth vertical head drive gears applicable to 2H/2CH
    These are 4.025" on the oft missing 30T spindle gear, and 3.222" on the 24T installed in the head assy
    Since these roll together and control gear mesh, I am going to assume these are very near the actual pitch diameters of these gears
    By adding these two together, we get double the center distance = 7.247"
    Making center distance close to 3.6235"
    You can follow along in the math operations on page 15 in Earle Buckingham's Manual of gear Design - Section 3
    Mike said he used 9DP cutter
    Helix angle calcs out to 34.1134404 degrees
    Lead for 30T calcs out to 18.672175".
    Mike came close and used 18.626" when he set up his Low Lead box. He shows a photo in a recent thread and even specs the gears needed right from the Tables of Leads for the Model H DH
    Be sure to double check the gear setup in your lead box.. I think this is the correct setup for cutting the gear in question.. Ramsay 1
  3. Likes Hobby Shop, sfriedberg liked this post
    Jul 2004
    Houston, TX USA
    28,854
    Related thread: (at least the recent posts)
    Looking for kearney & trecker driver gear
    As to the DOING, you have to pay attention to the HAND. If the driven (24 teeth above) is RIGHT HAND helix, the driver (30 teeth above) HAS TO BE LEFT HAND
    And Greg, to answer your question on O.D., you would add two 9DP addendums to the 4.025, making a 4.2472" O.D. 30 tooth gear
    Mike: If you will, check the "B" and "C" dimensions on page 4 in the link in Post #61 of the thread linked above. Have any explanation of WHY that info comes up with a THREE INCH center to center value for 2H?
    j
    Jun 2015
    Tennessee
    9
    If you are interested, I have one for sale. Sent you a PM.
