I've bought a Cincinnati Toolmaster 1D, got it home and into the shop, nobody got hurt, no damage. Saw it running under ordinary 3-phase power. Would like a reality check on the electrical system.
Back panel label: CIMTROL 2-phase
Motor nameplate: Standard Electric Div of Dayton,
model: 3062 Type: OS
Ser: CW13005 PHASE: 2 (yes, two)
Amps: 5.6-2.8 RPM: 1700
Wiring label on motor shows:
higher:
ph 1 wires go to 1+7 and 5+3,
ph 2 wires go to 8+2 and 6+7
lower:
ph 1 wires go to 1 and 3,
ph 2 wires go to 2 and 4, connect 5+7, connect 6+8
Incoming 3-phase goes first to an external box containing 2 transformers, labeled "3-phase to 2-phase only" dated 1997,
and the output 4 wires go into the CIMTROL panel.
I guess this machine was a 2-phase converted in 1997 for 3-phase by adding the transformer box. Does that sound right, or all they all like this?
My shop has no 3-phase but I have an inverter; the inverter wants to be directly connected to a motor.
So I think my plan is:
Wire the inverter to the transformers and wire them direct to the spindle motor bypassing the panel. Maybe that will make the inverter happy and the machine usable, don't know yet. For now, don't use the power feed or the coolant pump, figure those out later.
Any thoughts? suggestions? I appreciate your experiences.
higher:
lower:
