JohnOfAllTrades
- Apr 20, 2012
- SF Bay Area, California
Hi,
I'm a happy new owner of a Toolmaster 1D, rescued from a garage in California. Seem to be in pretty good shape overall. The ways feel nice and smooth. Got lucky as it was already running on 220 with a small built in capacitor phase converter. After reading the forums here I'm making the move from monoset to ER40 collets. It has the quill lever oil leak, but I'm a little nervous about getting in there and replacing the seal right now. It has the X table power feed. The right hand selector was frozen, but after taking the front of the gear box off I found the sliding gear was glued to the shaft with oil turned to tar. After much WD40 and penetrating oil, it now slides fine. I did find a part in the bottom of the gear box that looks like a broken "Pin Follower" part number 134b in the manual on the Table Power Feed Gear Housing page. The power feed was working to some extent though. Move the control lever to either side and the table moves. Was the cam follower a mechanism to auto reverse the table when the control lever hits the dogs? I hear clicking noise in the area of the back gear at certain spindle speeds. I'm thinking that's not normal, and considering how old the oil was in the power feed, I'm worried about the back gear oil and the spindle lubrication. I have the "Service Manual and Parts List Catalog" and the "Operators Manual" but can find no mention of back gear or spindle bearing lubrication for the 1D. So here's my questions:
1) Is the cam follower in the X power feed for auto table reverse?
2) What lube is used for the back gear, and how do you get it in there?
3) What lube is used for the spindle bearings and how do you get it in there?
4) I have the motor housing off the mill and am looking at the backgear cover plate. How do you lift it off to check the backgear for the clicking noise?
5) How do you get the top cover off the power feed to replace the cam follower pin? I took the bolts out and worked on it a while, including a bolt on a lever down into the oil hole, but I can't get that cover to budge.
Thanks!,
John
Thanks!,
John
