Froneck
Titanium
- Dec 4, 2010
- McClure, PA 17059
Does anyone know the number of the spindle bearings for the 1-D type vertical head on the other side of the H-V ram? I did replace the bearings a few years ago, saved the box cover with the bearing number but can't find it. Reason I ask is a while ago I was asked to rebuild a few newer Bridgeports (Taiwan built Hardinge machines) I still have a complete bearing set with Fafnir/Timken JM207PPPRBDBC4FA52730 lower spindle bearings. If they are the same I'll keep the bearings. Also interested in the upper spindle bearing number so as I can keep all the bearing I can use in my ToolMaster. I doubt I will ever need bearings for the other side spindle since it was hardly used nor do I use it very much but does come in handy from time to time. I do have a K&T Horizontal Mill.
If the bearings are not the same I'll simply sell the complete set.
