Uglydog
- Mar 19, 2011
- Dayton, MN, USA
I've been working on the reassembly of a VN22LU. She came in 3 milk crates. Pieces missing, pieces broken. Finally sorted all that out. Huge jigsaw puzzle which included making some gears and shafts. Regardless, I believe I may have found the original problem. The clutch assembly has plates which are clearly deformed and worn.
I'm having difficulty figuring out how to extract the assembly. Might be as simple as a burr on a keyway...
Has anyone had experience with the extraction? The exploded view in the many manuals I've collected don't show all the parts which are actually part of the machine. Close, but not complete.
Replacing the clutch or plates will likely be impossible. Once I get her apart I will have to investigate the possibility of fabrication of clutch plates. First I need to get her apart.
Any ideas?
Thank you,
Daryl
MN
Any ideas?
Thank you,
Daryl
MN
