VN 12 5c to jacobs taper for drill chuck.
Likes Likes:  0
Results 1 to 6 of 6
    Mar 2010
    pacific northwest
    924
    6
    173
    Default VN 12 5c to jacobs taper for drill chuck.
    For drilling small holes on the VN 12, I am limited to finding a lot of odd collets, or using a drill chuck with 1/2" straight shank in a 1/2" VN collet.
    I have a couple spare blanks made up from 1144 stress proof, with the VN taper , threads, keyway and drive lugs already cut- I am thinking about putting one on the the lathe and turning a Jacobs taper for a drill chuck.
    Any advice on this, like what size drill chuck to use and what Jacobs taper to turn? I don't know a thing about the Jacobs taper,angle, size, etc, except that they fit drill chucks.
    Is there a size chart around for the Jacobs taper?
    Any brand of moderately price chucks ya'll like? (moderate-$75-$200)
    Thanks, Stoneaxe.
    Oct 2010
    Moscow,Idaho,USA
    1,027
    1177
    441
    The Jacobs taper dimensions are in the Machinery's Handbook.
    Dec 2013
    Vermont, USA
    411
    6
    98
    There were VN OE collet-like adapters that had an inner Morse Taper #2, which would allow you to then have multiple MT2 inter-adapters for different Jacobs chuck sizes. Downside would be that you would have one more intermediate interface to contribute to 'tolerance stacking.'
    Sep 2002
    Arizona
    3,461
    723
    442
    Frankly, you're better off using a center drill in a collet to locate the holes, then drill the holes on a drill press. By the time you put a chuck and a drill of any size in a Van Norman, you have very little space for the part. Especially if you're using a vise.
    Cal
    Mar 2010
    pacific northwest
    924
    6
    173
    Quote Originally Posted by Cal Haines View Post
    Cal
    Cal, I can see that working well if the part is simple and easy to re-index- and I get the part about the vn having little clearance under the head. For horizontal drilling it is not too bad, as the ram can be retracted.
    I am actually rethinking this once more, and considering using a VN5C to ER 20 setup, to shorten the chuck length. I will probably buy a set of screw machine length drills also.
    I called Hardinge today to see if they would make one, as they are all set up for collets, they must have the dimensions. Or maybe use a ER20 to 5/8" straight, I have a very short 5/8" VN endmill holder it could go in.
    Just playing around with ways to hold smaller drills, etc.
    Sep 2002
    Arizona
    3,461
    723
    442
    Another option is to make a 5C to MT2 adapter and buy a set of MT2 collets. You can get a set on Amazon for $42 (link). That would also allow you to use an MT2-shank ER chuck.
    Cal
