FirstEliminator
Cast Iron
- Jul 4, 2007
- North Adams, Massachusetts
Hi,
The VN 21 or 2I that I've been using for the past 8 years has some wear in the head. I feel this is going to be a problem for boring an accurate hole. I haven't taken the head apart, but I have tried to adjust it. It appears there is a tapered bushing that the spindle is drawn into. The problem is, if I don't have a little bit of slop, then it starts to bind up. Or, if I attempt to drill a hole the spindle gets pushed into the taper and stalls the machine. The only way to prevent stalling is to constantly pump oil into the oil cup to create oil pressure to hold the spindle from locking into the bushing. Is this bushing restorable? Is there a bearing type head that can be mounted on the ram?
thanks,
Mark
thanks,
Mark
