michael.kitko
Cast Iron
- Oct 30, 2012
- Pontefract, UK
Well, I don't think my shift tumbler was disengaging properly and I went to roll the front selector. I experienced a load of resistance and stopped and took the nuetral lever a bit further than the stop. It then shifted fine. I then couldn't get it to go back in gear without messing about work the feed shaft. I then turned the thing back on and heard this weird chatting noise. I don't know if it was the switch, contractors, or feed, but I decided to open it up on both sides to have a look. I found a broken gear that applies the rapid speed. Other than that it looks fine. One of the questions I have is, is it normal for the low/high speed ratchet clutch to engage like that? You can see in the picture that it looks like the flats are out of alignment. When I rotate the feed shaft, they line up after a second or two. My other question, is this thing designed to have feed speeds changed while it's running? It seems like it should be. Lastly, do you think I broke it by having it not fully out of the low setting? It does say that it "must" be in nuetral while shifting the tumbler. Thanks in advance.
Sent from my S61 using Tapatalk
