What can you tell me about this 13" Leblond?
Results 1 to 4 of 4
    Aug 2017
    Ohio
    167
    49
    5
    Default What can you tell me about this 13" Leblond?
    Sorry if this is the wrong forum or area, there isn't a Leblond forum on there. I found a Regal 13" Leblond that's in great shape, allegedly never used in industry. Haven't checked it out in person yet. All the original paperwork is with it. Would a Regal 13" have power feed and power cross feed? Other thing that's tripping me up is the motor and the RPMs. It's got Timken bearings, but is still only 750rpms? That seems slow. The lathe is allegedly run on a 3/4hp 110v motor, so i'd likely be upgrading that to a more appropriate HP rating.
    00k0k_5amysz0okxdz_0ak07k_600x450.jpg00101_4yatxnseclmz_0ak07k_600x450.jpg00808_lft5a95il4z_0ak07k_600x450.jpg00d0d_1mg6ishmlgoz_0ak07k_600x450.jpg
    Jul 2004
    Houston, TX USA
    32,129
    They were not fast because it wasn't done that way 70 or so years ago on small light duty lathes
    Handy info from those days
    Especially Running A Regal
    R. K. LeBlond Machine Tool Co. - Publication Reprints | VintageMachinery.org
    have fun
    (there are higher speed Le Blonds - somewhat later than this Regal - Dual Drives they are called - with top ends to nearly 2000)
    Aug 2003
    port allen, louisiana usa
    1,889
    545
    469
    Default Early LeBlond Lathe
    I have the 15" machine similar to the one you are referring to.. My machine was made in 1941... Top speed on my machine is 500 RPM.. Borderline for inserted tooling...I use mostly hi speed tools in the old rocker tool post....Here is a spindle adapter I made with my 15" trainer... The milling of the slots, of course, was done on my 1943 Kearney and Trecker...... Cheers; Ramsay 1
  4. Likes ratbldr427 liked this post
    Mar 2006
    jacksonville,fl.
    1,489
    1465
    506
    I have one like that.It will do what you ask.Normally don't come with metric threading gears. I don't see why you couldn't step up the speed to 1000.The plain bearing spindles on the older machines was the hold back as for increasing speed. Yours like mine has Timkins so I don't see why it would hurt.It's splash oiled so maybe might leak a little,don't know if any changes were made in the head when they went to higher speeds. The rest of the gear train is very similar to the later high speed Regals. I use a 15" 70's Regal at work all the external gearing looks the same.
    That looks pretty nice.It's just not a hogging machine.If the price is right and it will meet your needs jump on it,they are nice machines.
    I put a 3hp motor on mine just because I had one but if I had to buy one I wouldn't go over 2 hp.
