Worm & worm gear questions.
Page 1 of 3 123 LastLast
Results 1 to 20 of 54
    Mar 2014
    Michigan
    701
    111
    247
    Default Worm & worm gear questions.
    Hi guys.
    I'm missing all the worms & worm gears for my K&T 2CHL.
    The ratios are. 1:96, 1:24 & 1:3.
    Ramsay1 measured one gear for me and now I'm trying to figure out everything else.
    I measured the center distance between the worm gears the best I could. I used gauge blocks between the 2 shafts and got 1.496 (each shaft is 1.312). Center is 2.808". I must be doing something wrong because using his measurements, I'm coming up with a different center dimension .
    Center = 0.5(d+D)
    [2.6860"]
    OD of worm gear is 3.9" with 24 Teeth
    DP---- 26/3.9 = 6.66666
    CP---- 3.1415/6.6666 = .4712
    PD----24/6.66666=3.6
    I'm also trying to find the lead of the gear but every formula I'm looking at in the machinery's handbook has the helix in it....Is there a way to solve for the helix angle with the info I have?
    Worm, OD is 2.215"
    8 teeth
    Dp = 4.5146
    CP = .6958
    PD = 1.7720
    I've got lots of books and I'm trying to learn as much as I can but gears are new to me.
    Any and all help is always appreciated.
    Andy
    Jul 2004
    Houston, TX USA
    28,867
    Forget the second set of calcs as on the worm - you are using spur gear procedure for finding DP of worm - never happened
    What you are interested in is its pitch dia and lead - which has to match the CP of the mating worm wheel
    I'll look in Buckingham and see what I can come up with - if anything (nothing, just looked)
    This is a usually CLEAR book - the worm gear section starts on page 310
    Internet Archive: Error
    Quote Originally Posted by Hobby Shop View Post
    Hi guys.
    Center = 0.5(d+D)
    [2.6860"]
    Worm, OD is 2.215"
    8 teeth
    Dp = 4.5146
    CP = .6958
    PD = 1.7720
    Andy
    Sep 2005
    Oakland, CA
    2,316
    201
    601
    Start with the worm itself and measure the axial pitch- you can get close with calipers, but more accurately, use a comparator or mount the worm in a lathe, zero a test indicator on the worm flank at any depth you choose, move the cross slide out and move 4-5 leads and bring the indicator back in to the same depth as before while measuring the carriage travel- move the carriage to bring the indicator back to zero. your carriage travel divided by the number of leads you skipped is your axial circular pitch. (im assuming here you don;t have access to a lead checker.) Calculate the addendum for that circular pitch and use the worm od to calculate the worm pitch diameter. Now take that circular pitch and multiply it by the # of teeth in the worm wheel.
    The result is the circumference of the worm wheel pitch diameter. Calculate the pitch diameter of the worm wheel (pi*pd= circumference).
    Now you can calculate your center distance 1/2 worm pd + 1/2 worm wheel pd. This should be close to your measured centerdistance unless there is a profile shift in the worm wheel, which is entirely possible with several ratios fitting on the same centerdistance. Remember that the WORM PD and axial pitch dictates the lead of the gear set and the dimensions of the worm wheel. Hope that gets you started. Dan
    Apr 2013
    Damascus, MD
    1,343
    3819
    758
    Andy,
    Unless you enjoy the project of calculating and building from scratch the worms and worm gears, I'd suggest to shop for a donor/acceptor machine or parts salvaged from one.
    If, instead, you enjoy the challenge, I'd suggest you start from a scenario where you have the mating pair to measure: measure the distance between the shafts, make your calculations, and verify your results by checking the dimensions and angles on the existing worm and worm gear.
    Paolo
    Mar 2014
    Michigan
    701
    111
    247
    Thanks John.
    I'll do more reading. I have a copy of the 3rd edition and I didn't even think of referencing it. This might take me a while but I'll eventually get it.
    Thanks Dan, lots of to digest there.
    I don't have access to the original gear(s) so I'm winging it.
    What I do have.... is a set of gears for a different LL box gears (5814). I'm hoping we hit a home run because all the worms are within 1/8" of being the same length but different OD's.
    You gave me an idea. I have a Weldon air bar, what about mounting the worm like an end mill? Measure the start on the BP, rotate 360* & measure again with the readout. That would give me the lead. Work everything backwards from there for the helix angle. Does that sound reasonable? If not, I'll try the lathe.
    Here are a few pictures of the gears I'm after. Once I get all the #'s to make them, I might send them to you or someone else to cut them. I know it won't be cheap but I want it be 100% correct.
    Andy
    Attached Thumbnails Attached Thumbnails image.jpg   image.jpg   image.jpg   image.jpg
    Jul 2004
    Houston, TX USA
    28,867
    As can be seen, the 3 to 1 has MULTIPLE starts, which means the LEAD will be much longer than the apparent "pitch"
    24 and 96 are both single start
    Mar 2014
    Michigan
    701
    111
    247
    Paolo,
    Not that it couldn't happen but finding the parts from a donor machine is going to be almost impossible. The gears are always the first things to get tossed. These gears are for the last attachment I needed to complete mill. The math isn't hard, a little algebra & trig. It's the terminology/nomenclature, It's all new to me. I think cutting the gears will be the real challenge. If it is and after the 2nd or 3rd set I mess up......I'll make the blanks and job out what's beyond my pay grade. I'm not on any time schedule to get this thing finished, it's a hobby for me and I enjoy learning new things.
    Andy
    Quote Originally Posted by Paolo_MD View Post
    Andy,
    Paolo
    Mar 2014
    Michigan
    701
    111
    247
    Quote Originally Posted by johnoder View Post
    That was some of my confusion. With 8 starts, I wasn't sure if it was still considered a worm or a helical gear.
    Jul 2004
    Houston, TX USA
    28,867
    Not to worry about names.
    Helical gears have leads when you mill them in a Universal mill
    Mar 2014
    Michigan
    701
    111
    247
    edit: I'll clean it all up and repost.
  11. #11
    Jul 2004
    Houston, TX USA
    28,867
    Has lead of worm been measured?
  12. #12
    Mar 2014
    Michigan
    701
    111
    247
    Not yet John, I'm going to clean up my numbers and repost everything later.
  13. #13
    Sep 2005
    Oakland, CA
    2,316
    201
    601
    If you are going to measure the helix angle on a comparator, be aware that the angle changes with the diameter or radius. You can see this visually by looking at the angle at the OD and comparing it to the angle at the root. This is why its best to measure the lead and calculate the lead angle. FYI, the lead angle is always specified at the pitch diameter.
  14. Likes Zahnrad Kopf liked this post
  15. #14
    Mar 2014
    Michigan
    701
    111
    247
    Quote Originally Posted by Dan from Oakland View Post
    Unfortunately, I didn't see your post before I left and measured it. Looking at the gear, I see exactly what your talking about. I'll double check the (1:3, 8 thread worm) lead by measuring it. I measured the worms like this picture. This is my first gear. they're completely new to me. With everyone's help (thanks) and a lot of reading, I'm learing this as I go.
    Andy
  16. #15
    Mar 2014
    Michigan
    701
    111
    247
    I measured the worm lead and lead angle on the shadow graph. This is what I have for the 1:24 worm/wheel. I'm within .0015" of the fixed centers on the 5814 box. I'll remeasure the worm and wheel but I'm pretty sure the numbers are good. I'm still working on the other gears.
    Andy
  17. #16
    Jan 2010
    Indianapolis
    1,349
    778
    414
    I'd give up on the worms and install a planetary gear set (or two) from an automatic transmission and generate a new table of leads with a spreadsheet.
    The range of leads on a KT low lead attachment are insanely broad. When did anyone need a 122 inch lead?
  18. #17
    Jul 2004
    Houston, TX USA
    28,867
    When you have a good solid worm lead - as Dan described the procedure for obtaining - you can run the numbers the other way from that
    As it stands, you are basing your pitch on the wheel on assumptions, like 5 degrees, and obtaining the .534 lead on that (not that your tiny photos lend themselves to being legible)
    As an example of the built in errors:
    If lead was actually .53445 and PD of worm was actually 2.409, the angle would be nearer 4.04 than 5 degrees
    Andy
  19. Likes Zahnrad Kopf liked this post
  20. #18
    Jul 2004
    Houston, TX USA
    28,867
    Here is a larger (hopefully) image Andy emailed
  21. #19
    Feb 2015
    Massachusetts
    25
    John and Andy,
    If I have interpreted the equations from Brown & Sharpe, Formulas in Gearing, 1905 edition, and 20th edition of Machinery's Handbook here are a set or worm/wheel parameters for this example. This example is intended to be the same design that Andy is working on.
    I have a simple spreadsheet which allows me to quickly modify the design parameters and find and correct errors in my interpretation of the terminology and formulas.
    The goal of the spreadsheet was to create a design which generated a worm wheel that would fit through the 4.5" round opening in the LL gearbox housing.
    As an aside, I found it difficult to post this type of material.
    Bob
    2H - 1 to 3 ratio 8 start Worm/Wheel Gear Set
    Worm TPI, TPI ~ threads per inch (a single continuous thread), 0.232, Input(*)
    Center Distance, C = ( D + d ) /2, 3.250, Input
    Number of Teeth on Wheel, N , 24, Input
    "Worm Multi-start, MS = 1,2,3, etc", 8, Input
    Worm Lead or Axial Pitch, L = 1 / TPI ~ inches per (a single continuous thread), 4.307,
    Wheel Circular Pitch same as Axial Pitch for Worm, CP = L / MS, 0.538,
    Worm Addendum, S = 0.3183 * CP, 0.171,
    Diametrical Pitch, DP = Pi / CP, 5.836,
    Pitch Diameter of Wheel, D = N * CP / Pi, 4.113,
    Pitch Diameter of Worm, d = 2 * C - D, 2.387,
    Worm OD, o = d + 2 * S, 2.730,
    Whole depth of Worm, W = 0.6866 * CP, 0.370,
    Worm Helix Angle, B = ( 180 / Pi ) * atan( Pi * d / L) Degrees, 60.136,
    Worm Lead Angle #12, La = (180/Pi) * atan( L /( Pi * d ) Degrees , 29.864,
    Norm Pitch of Worm #(1), Pn = CP * cos( (Pi/180) * La ), 0.467,
    Worm Thread tool Tip, T = 0.31 * CP, 0.167,
    Wheel Throat Diameter, O = D + 2 * S, 4.455, K&T 2H Low Lead Housing Opening for Wheel ~ 4.5”
    Gashing Angle of Worm Wheel, GA = 90 - B (degrees), 29.864,
  22. #20
    Mar 2014
    Michigan
    701
    111
    247
    Here are the all the worm & worm gear measurements for the K&T 5814 Low lead.
    1:3
    Worm OD = 2.740"
    Gear OD=4.454"
    1:24
    Worm OD= 2.750"
    Gear OD = 4.454"
    1:96
    Worm OD=2.250"
    Gear OD = 4.495
    Gear Box worm/wheel center = 3.262"
