.001 position call out to od to od. Shaft dia is the datum. No matl condition
Results 1 to 9 of 9
    Sep 2019
    Florida
    Default .001 position call out to od to od. Shaft dia is the datum. No matl condition
    .562 dia shaft over 4." long with a .194 dia thrd relief at .6 long with a .250 -28 ext thrd at the end .300 long. I turn it all together with the tail stk ingaged the tail stk is running concentric to my chuck within .004 (not bad) but after i turn the part, and all is running concentric with the tail stk ingaged, when i retract it an remove the part from the machine the .194 dia springs enough that i have as much as .002 run out at the end (the thrd pd)
    i have a .001 potion call out thrd to .562 dia. (which works out to .0005) would that head stk being off from the tail stk cause the problem i cant consistently hold true postion for the run out. (no matl condion call out)
    [email protected]
    Nov 2013
    Utah
    4,482
    1182
    2462
    How are you verifying TIR from the Threaded part to the .562 Diameter?
    R
    May 2011
    New Jersey
    1,987
    181
    1111
    R
    Did you read the tailstock is out 4k? I'd start there.
    Nov 2013
    Utah
    4,482
    1182
    2462
    If everything is on dial in the Machine, the TS shouldn't have anything to do with runout. Unless of course a person is using the same center hole to do final inspection. That's why I asked....
    R
    May 2011
    New Jersey
    1,987
    181
    1111
    R
    Hy lilrob
    That's where I figured you were going
    Dec 2011
    324
    44
    139
    Quote Originally Posted by Turnmaster2 View Post
    [email protected]
    I hv a sm fvr to ask. Cn u typ out ur wds cmpltly?
    Aug 2013
    stockton ca.
    27
    15
    Apparently you are not the turn master.
    Nov 2013
    Utah
    4,482
    1182
    2462
    Quote Originally Posted by Radar987 View Post
    ROFLMAO. Eyme n gi, pet is 2019 bro.
  9. Likes Matt_Maguire, digger doug liked this post
  10. #9
    May 2011
    New Jersey
    1,987
    181
    1111
    Dafuq lol???
