.03" corner rounding endmill
Results 1 to 9 of 9
    Oct 2019
    Idaho
    Default .03" corner rounding endmill
    I need help locating a corner rounding endmill that looks like the picture. the radius is .03". any help would be appreciated.
    May 2005
    CA
    1,130
    9
    287
    AB Tool might have it, or could most likely make it for you in short order:
    Carbide Tipped Corner Rounders | AB Tools, Inc.
    PM
    Apr 2019
    Arkansas
    875
    285
    327
    Wouldn't need that corner rounder if you made it in the lathe .03" corner rounding endmill
    Sent from my Pixel 3 using Tapatalk
  4. Likes lumley32 liked this post
    Feb 2013
    Madison, WI
    1,029
    1136
    673
    This may get you there if you can afford to stay off the part a couple thou. Or you could notch out the shank a little on a grinding wheel.
    https://www.mscdirect.com/product/details/79572913
    Sep 2015
    Ohio
    1,154
    707
    1144
    That sketch looks like about a 1/16 shank. Probably won't last too long.
    What about a concave lathe bit in a flycutter?
    But, yeah. Lathe.
    Jul 2012
    Washington
    2,934
    1139
    1186
    I have seen tools that are radiused top and bottom that would work, but can't remember where. Sorry, but it is out there.
    Jul 2010
    northern illinois
    58
    9
    Quote Originally Posted by cv321 View Post
    check out ingersoll chip surfer line. it will most likely be a special but it does open up the option for other tooling choices for later use
    Chip Surfer
  9. #8
    Feb 2004
    Staten Island NewYork USA
    3,764
    1106
    1801
    Or Harvey tool
  10. #9
    Jun 2009
    140
    89
    38
    Full Radius, Top and Bottom Corner Rounders | AB Tools, Inc.
    May need to neck it back further but this will get you going.
