alphonso
Titanium
- Feb 15, 2006
- Republic of Texas
Popped up in middle of program while we were at lunch. Luckily tool was not in the work.
Anyway, 414 is HCAL B65005E/05 essentially says the motor, cable or transistor module is bad.
Disconnected motor power wires from board. Still get 414. First glance, would seem like error is on board.
Unplugged encoder from board with motor disconnected and get expected 401.
Getting continuity from each motor wire to ground. Have not disconnected wires at motor yet. Takes about an hour to get to motor.
Also getting continuity at board between X1,X2,X3 terminal and ground.??????
Correct procedures???
Chances that it has taken out transistor module????
