What kind of shit drills are you buying?! A very quick glance at this with Mitsubishi MVS drill, 300SFM, .006 IPR, starting feed slowed down to .002 IPR in order to not use a starter drill (pilot hole), 300psi through coolant, I'd be looking at 20-22 minutes for all 150 holes, and that is if tool life is more important than cycle time. 8.8 seconds per hole, worst case scenario.In a CNC mill with carbide drills and through coolant maybe 2-3 minutes a hole.
I need to make about 20 different shape profiles of Exhaust manifold flanges out of 1/2" thick carbon steel sheet and about 50 pcs of each of the profile.
I plan to first make out rough profiles by joining 6 plates ( Total thickness 3") and then drilling out 1/4" holes ( appox 150 of them) just touching one another. Once this rough profile is ready by drilling ( Most inexpensive way) then I can make final cut by end mill.
What I think is that this is the most inexpensive way.
Please do let me know if it is workable.
I can get them cut on laser but as secondary operation of grooving etc, these have to be machined again on CNC.
If rough profile is workable with drilling, this profile will be breakable from base plate and then one by one each flange can be machined with minimum chip removal on outer surface using bolting holes created in first operation as clamping
We're going 2.45" deep through 304 with an 8.4mm MVS drill right now. 225 SFM and .006 IPR with no drama. So what's that, 12 seconds per hole or so?8.8 seconds sounds a bit optimistic...maybe you should try it
...About a month with my Makita cordless....
That was good for a little spew on the monitor.
How much time it will take to drill 150 holes 1/4" in Dia in 3" thick carbon steel plate
at 3 ipm feed with hss drill thats 1 minute a hole if pecking figure 2 minutes a hole. long carbide drills obviously break very easily. sure shallow holes carbide feed maybe 6 to 30 ipm feed
BUT as some will say some steel got slag hard spots in it. hit one and break drill and if you got to get drill out and finish drilling it could take some time. often any failure corrective actions can take hours.
.That "some" is only you.
Yes, sometimes hard spots in casting making tool jump and cause sudden tool breakage then take notes in excel so I can show everyone how it's done
im sure Tom isn't perfect. im sure im not. and im sure the rest of you are not. I doubt one of you in 200 could walk up to a very large gantry mill or horizontal boring mill and even begin to load, clamp and mill a 3 ton casting with no machined reference surfaces. could you run a portage layout machine to put start reference lines on the casting for him? and how those lines are balanced around all the casting surfs for best equalization? I didn't think so. stick that in your kurt vise.
Notice
