1-5 internal acme
primeholy
Sep 27, 2016
I'm looking for an indexable tool to cut 1-5 internal acme threads on a mill. I need to cut a little over 1 inch deep. I just sent an email to Vargus and Iscar. Anyone currently milling 1-5 acme internal threads and have a suggestion?
Vargus has an online software that tells you what tool to use, it's pretty slick.
You can also download an offline version.
1"-5 2G internal they suggest this tool, doesn't appear to be an indexable though.
VARGUS GENius
Looks like maybe they don't offer indexable in that size. It seems this is solid carbide, unless I'm misinterpreting. I am easily confused :o
Had to do, I believe it was a 1-5 many many years ago.
And then I started thinking about the threadmilling, and somebody,
it might be those guys up there sold a threadmill. So I just HAD
to draw it up to see if it was actually possible.
Its not, you blow out the entire thread form. Might as well just
use a key cutter, it'll do the same damn thing.
External, I think it would be possible to get an acceptable thread form,
internal, not a chance, unless it was a massive diameter, and an itty bitty
cutter.
Its just too steep, and the included angle is too narrow.
Get a tandem tap. If your machine doesn't have the nuts for driving it,
thread mill the form of the first section of the tandem tap(standard
single level threadmill), then it goes in nice and straight, and makes
your life a little easier.
Bobw is right in theory even though I have an ADVENT 5 pitch acme threadmill(S010558-BH3FAZ) that we successfully made some 1 x 5 nuts.
You ever check those nuts for proper threadform? Probably nothing stopping them from screwing on the mating part, they just won't have proper flank contact.
I've been through this long ago and came to the same conclusion as Bobw.
I just can't see any possible modified geometry that would generate the correct form, which leaves three options for the available to buy acme threadmills.
1. They have some compromised geometry that sort of kind of fudges a sort of kind of functional thread, or
2. The manufacturers of said threadmills don't care that their customers are going to make non-compliant threads, or
3. The manufacturers of said threadmills just ground the threadform without any checking of function and are unaware that their customers are going to make non-compliant threads.
Edit:
Fourth option, manufacturers of said threadmills have some fine print hidden away somewhere stating that 5 axis is required to use their threadmills.
VARGUS GENius
I don't remember but this may be able to tap, Had issues in the past with jobs like this.
there was a supplier near Los Angeles USA , that would mfg the tap and go & no go gages, it's long shot
having a brain fart remembering the company name.
OP, do you have rigid tapping? If so use a boring bar with the correct shape tool in a boring head. Tap, adjust tool out, tap, adjust, tap, etc. May not work with a carbide insert though, tool dragging on the way out.
Ed.
Edit:
We did cut a test piece in half and used a Topnotch insert to eyeball the shape. The form was screwed up(wide) at the crown of the thread for about .015". Looked kinda like a big chamfer. Put some Silly Putty in customer's sample and it showed the same non conformity. They haven't complained about it since put in service over a year ago.
Not sure if anything was decided here since the post got a little cold but no one has mentioned Carmex. They have a solid carbide thread mill for 5 pitch. I can't say for sure if it will work on a 1" but that is a pretty standard thread no? Would it not be designed to work for the most common use case?? We used one a while back because set up can be a pain in the ass on those taps since you need to go through the part by like 4". I believe it was a 1"-5. Think it took 2 passes. I didn't run it but I made the tool recommendation so I was somewhat familiar.
(edit)
Forgot to address the request for indexable. That to my knowledge doesn't exist but depending on your qty solid carbide will be the way to ge because you get a lot of flutes and more speed. Going to take forever with 1-2 flutes which is probably why no one has tackled the pain in the ass and highly niche task of making indexable at that size.
