I would like some opinions on whole degree indexing on a horizontal with a 4th axis. Does it cover enough of the work (job shop) to justify it over a regular 3-axis with 90 degree indexing?
no ideal on cost. curvic gear every 1 degree has stronger clamp ability for roughing. many a rotary table will fault if moves .01 degree or .001 degree so same part needs to run at reduced feeds and speeds on a finer adjust rotary table usually depends how big the cutter. obviously rotary table only takes seconds to rotate. usually 3 sides at least done with same program. sometimes many parts setup on column or tombstone. some doing many dozens of parts at a time. programming can be more difficult. part loading unloading takes more time usually multiple pallets for one cnc so setup loading done while other pallet in cnc running program. pallets cost money too. automated pallet system with over 30 pallets can be very expensive
some curvic gears have limited electronic adjust, obviously mechanical adjust more difficult for grid shift and center of index calibration.
There was a thread a short while back asking a similar thing (though it was 1 degree vs .001 degree indexing between horizontals)
Used HMC decisions, full 4th ?
Seems for most people, 1 degree is enough. It would be enough for me too. however, I have 3 horizontals with full 4ths (.001) and I love the fact that I can slap a fixture on there and not worry that it is indicated in within a degree. I can usually just bolt, set B to whatever random angle it is at, and go.
Occasionally there are parts with fractional degree features but they are relatively rare.
Edit: I am dumb and see you were asking 1 degree vs 90 degree indexing on a vertical mill. Apples to oranges.
Horizontals are great for the job shop, although they are more expensive and have more of a learning curve. But I consider them essential for what we do now. We run a lot of things on the horizontal that the company had run 10-20 years ago on verticals, with many improvements in cycle time and accuracy, etc.
For -operators- who may struggle with adjusting offsets on a vertical mill, I find it near impossible for some of them to understand how to adjust an offset on the horizontal. Too many sides? Too many things moving?
Notice
