shaffin
- Jul 15, 2011
- Barrie, Ontario, Canada
So I got my hands on a 1994 Fadal VMC-15 with the 88 control (I have never owned a Fadal before nor do I have any experience with the Fadal 88 control), but not sure how to validate some of the options on the machine is equipped with, such as:
1. Spindle speed... when testing we were able to test 5000 rpm at 100%, and were able to override it that by hearing the spindle did run faster... how do I check whether it is 7500rpm or 10000rpm?
2. Is there some place to detect whether the machine has Rigid Tapping?
3. Is my only way to run a program using manual GCode creation at the control and using DNC? The reason I ask is that the process I have been using in the past is creating drawings (DXF) and then using CamBam to generate GCode, then copying the GCode file over onto the controller to run - what is the common practise for Fadals?
4. Do the Fadals require spindle warmup time before using the machine, or is the program available within the Fadal 88 controller (I did see the operator using a CS routine that I guessing is the cold-start)?
5. If anyone can share a soft-copy of the various manuals (operator, programming, electricals, etc.) that would be much appreciated.
Thank you all,
shaffin.
Thank you all,
shaffin.
