1999 Fadal CNC 88HS
Results 1 to 3 of 3
    Aug 2019
    Missouri
    Default 1999 Fadal CNC 88HS
    The machine has sat for quite some time, and I just fired it up. It says it had some memory problems, but I got all of that straightened out. The machine will load a program, and follow all commands except for one. I set the turret position to one (SETTO command) and it will go to it, but it will not display the tool position on the screen. It says "Tool - ?", even though it will move to it in the turret. Basically, the machine knows where tool number 1 position is, and it will go to, but it wont tell me on the screen thats what it is, therefore not allowing me to set offsets or anything.
    UPDATE: THIS IS A 1996, NOT 1999.
    UPDATE: I FIXED THE ISSUE. ZEROED THE MACHINE AND REENTERED ALL PARAMETERS BACKLASH AND IT IS WORKING NOW.
  2. Likes Bobw liked this post
  3. #2
    Apr 2016
    Arizona
    284
    242
    126
    Can you get a tool number to show up if you manually command a tool change with "TC,1"?
    Aug 2019
    Missouri
    Nope, sure can't. The machine knows where the tools are because it will go to them, but it will not display it on the screen.
