2 05 haas vm2 question
Likes Likes:  0
Results 1 to 11 of 11
    May 2011
    New Jersey
    3,348
    372
    1908
    Default 2 05 haas vm2 question
    So we have a 2005 vintage haas vm2. It's a great machine, having the extra y is nice. I have 2 questions:
    1) the monitor has a dead spot, can we just replace the monitor or does the whole control need to be changed?
    2) in high speed toolpaths it really suffers in speed. What are settings to check to see if we can get any more out of it.
    Thanks!
    Oct 2015
    Oregon
    574
    247
    450
    I think the VM2 is their HD machine, so high speed toolpaths are not really it's sweet spot.
    Aug 2013
    Chicago, IL
    1,296
    935
    517
    We’ve got an 02 VF2 that was groin-grabbing your slow with the MasterCAM HSM tool paths until I loosened up the filter ratio” or whatever it’s called. So maybe double check how tiny the moves are. Good luck!
    May 2011
    New Jersey
    3,348
    372
    1908
    Thanks it seems that it won't go over 100ipm on radius moves, straight it takes off though. Someone on the other board suggested looking into g187 so that may be my next move.
    Aug 2013
    Chicago, IL
    1,296
    935
    517
    I assume it has the “high speed machining” look ahead activated?? You gotta pay for that one…
    May 2011
    New Jersey
    3,348
    372
    1908
    Quote Originally Posted by Nerdlinger View Post
    Do you know where that is, I just looked and couldn't find it.
    Aug 2013
    Chicago, IL
    1,296
    935
    517
    Off the top of my head I think it’s a “setting” or “parameter.” I think it has to be “1” instead of “0”…it’s either called “look ahead” or “high speed machining”. Good luck!
    May 2011
    New Jersey
    3,348
    372
    1908
    Couldn't find either and I went through parameters and settings 3 times. I did see that the default smoothing is set at finish. I'm interested to see what kind of change a rough cycle has in p1.
    Aug 2013
    Chicago, IL
    1,296
    935
    517
    All I could find on-line was that it looks like it’s parameter 315 switch 4. If you haven’t used it yet you should be allowed 100 or 200 hours of trial. Good luck!
    May 2011
    New Jersey
    3,348
    372
    1908
    Thanks, I couldn't get to it earlier now its magically there lol...with a 1 so it's on.
  11. #11
    Jun 2006
    Alabama
    1,954
    1117
    775
    All those machines came with "high speed machining" enabled standard.
    When you're roughing (leaving at least 0.03" or 0.04")
    run G187 P1 E.06
