Only have 4 sided Iron pallets now and need 2 sided for some work and realize the fixturing will be tricky enough that we probably want to just dedicate stones to the work, thus have more stones around.
It starts to add up quick! I am not yet sure what dimensions we need just yet, but looking more like rectangle type stones where 2 faces are wider, but the two narrower faces are still wide enough to add "something".
Most parts will be Aluminum with minor hog outs with a 3/4 cutter. Will need to go all the way to the top of the tombstone it appears.
We have lots of Aluminum around that would basically be free, but I don't want to go through the hassle if we will have chatter or finish issues? Aluminum gunna work or do we need Iron?
Also have some steel and Ti work, but not very much, and parts are not very big.
Any commercial modular type options would be great! I think we are getting pretty wound up in knots trying to find a solution for "every" part! Some need vises, some need dedicated fixtures, some need doves, some mitees, etc, etc. I think I am going mad with all the options.....
The other idea was a sub/fixture plate to mount to the stone? This might eliminate some of the concerns of swapping stones on pallets.
We are trying to avoid the costs of buying more pallets and permanently mounting stones to them.
