200,000 holes!
Page 1 of 5 123 ... LastLast
Results 1 to 20 of 90
Thread: 200,000 holes!
    Jan 2021
    New York
    71
    27
    Default 200,000 holes!
    For an upcoming project, I need to make 200,000 2.5mm thru holes in an approximately 5' square piece of G10, .2in thick. (That's POINT 2 thick - ninja edit)
    The weapon of choice is a Thermwood router and the software would be FeatureCAM.
    Not being all that familiar with the material, and for the sake of starting somewhere, I told FeatureCAM the material was "plastic" and that I wanted 3000 RPM and it gave me 4.22IPM as a feed. I called a 3/32 drill bit and the software said .0938 peck in a chip break cycle.
    Should I peck more? Less? Do those speeds/feeds sound like a reasonable starting point? (I will be given some material to experiment on).
    Also, I'm thinking with that many holes, drill wear/breakage will be a factor. My first thought was to program the holes in sections/quadrants (and since the entire piece of material will be Swiss cheese-ed, it looks like it's going to involve moving whatever clamping contraption I can concoct). That would allow me to restart a section, rather than start from Hole one, all over again....especially when the drill breaks on hole number 199,999!
    Given that I'm going to need to move clamps around, I'm pretty sold on the quadrant idea, but can I refine it further? I'm not sure if the Thermwood will allow you to search/start from a line number - if it does, could maybe I coordinate line numbers with holes, so that I can start somewhere in the vicinity of where the drill went south....or the power went out....or whatever.
    Thoughts?
    Feb 2007
    Aberdeen, UK
    4,499
    1635
    2081
    Quote Originally Posted by TwoWheeler View Post
    For an upcoming project, I need to make 200,000 2.5mm thru holes in an approximately 5' square piece of G10, 2in thick.
    Thoughts?
    Does your router have a toolchanger?
    Featurecam can do basic tool life management - switch to a different tool after x number of minutes.
    Sep 2015
    Ohio
    1,677
    1117
    1737
    Both your programming ideas are solid. G10/FR4 is a fiberglass laminate. It is going to be brutal on your drills. Even carbide.
    I did a job out of it once, but that was years ago so I don't remember much.
  4. Likes BT Fabrication liked this post
    Jan 2005
    The Netherlands
    6,593
    356
    1881
    A ratio of 20 is deep hole drilling territory
    how it would perform on the material in question I do not know
    Peter
    Nov 2004
    RC, CA
    2,187
    223
    472
    200,000 holes, pecking 2" deep? In G-10? (It's got glass in it)
    Rough guess is 3-1/2 months running 24/7, based on a minute a hole. Chip break wouldn't be sufficient, I don't think. You're gonna need a full retract to clear the chips.
    I'd think a diamond gundrill, and compressed air thru the tool to clear chips, would be the only practical solution. Which probably requires a different spindle.
    Jan 2014
    Oregon
    709
    174
    504
    At 200k holes I would be contacting some drill manufacturers. OSG used to make some really good plastic tools for CFRP, but I'm sure you can find more options as well.
    For that awful G10, you might want a dreamer or something unusual. This is going to take a lot of time, and burn up a lot of tooling. Having the right tool is going to pay off pretty quick. You need something specific for your application.
    A good sales rep can find the right tool and give you all of the parameters you need to make it work.
  8. Likes mhajicek, Squidmaster23 liked this post
  9. #7
    Sep 2005
    Oakland, CA
    2,900
    513
    896
    Talk to manufacturers of circuit board drills- PCBA fabs are made from G10 or G10 like material. Fabs are still cut out with routers and there is still a fair amount of through hole board technology out there.
  10. Likes JohnEvans liked this post
  11. #8
    Jan 2021
    New York
    71
    27
    Quote Originally Posted by gregormarwick View Post
    Sadly, no.
  12. #9
    Jan 2021
    New York
    71
    27
    Quote Originally Posted by wesg View Post
    DOH! I missed the decimal point in front of the depth dimension! The comma threw me off! Crap!
    I fixed it!
  13. #10
    Jan 2021
    New York
    71
    27
    It's ".2" thick. I'm an idiot.
  14. Likes michiganbuck liked this post
  15. #11
    Feb 2007
    Aberdeen, UK
    4,499
    1635
    2081
    Sadly, no.
    Well, I assume it has the ability to use more than one tool offset? (I know nothing about your machine, sorry)
    As long as it can do multiple tool offsets and your post can handle manual toolchanges, the tool life feature in featurecam should still help you avoid splitting the hole pattern up.
  16. #12
    Mar 2011
    SWITZERLAND
    1,087
    133
    441
    Water jet. Give it to a water-jet specialist.
  17. Likes mhajicek, BT Fabrication liked this post
  18. #13
    Jan 2021
    New York
    71
    27
    Quote Originally Posted by Mechanola View Post
    I thought about that. Haven't looked into it further, yet. Asked one place about laser drilling and they said it was way too big.
  19. #14
    Jan 2021
    New York
    71
    27
    I don't know all that much about it, myself! The current operator is retiring, so I'll be taking it over.
    I assume it does have the ability to use multiple work offsets, so that might be a very good way to break the pattern into manageable chunks and/or find a place to restart, should I need to.
  20. #15
    Mar 2011
    SWITZERLAND
    1,087
    133
    441
    Look, the water jet will leave relatively round holes, rather straight (cylindric). If you need them within tighter tolerance, a second operation might become necessary. I’m thinking of grinding laps you can do with the router, something fast on it like a Dremel with a corundum stone.
  21. #16
    Jun 2013
    Washington
    156
    34
    Hmmm! 2.5 mm holes 50 mm deep spaced with a web of about .9 mm. G10 (circuit boards) are normally drilled with short carbide drills. thin stuff ... 1.5 to 3 mm board.
    50 mm is 20X dia so easily qualifies for a gun drill. G10 is pretty abrasive since it is glass fiber filled. My off the cuff thought is to countersink since gun drills like to get started straight ... or provide a drill bushing to get it started straight. Use air to cool and evacuate the dust. Trap the dust with a vacuum of some kind. Diamond coating may extend the life of the drill.
    To put it mildly; a very interesting project.
  22. #17
    Feb 2005
    9,582
    16140
    11623
    Well now, I don't feel quite so sorry for you.
    Circuit board drill is where I would start.
  23. Likes DavidScott liked this post
  24. #18
    Jun 2013
    Washington
    156
    34
    I wondered about the 2" ... but.
    Oh well! Orders of magnitude only count in paychecks ... right?
    Modify my last post ... carbide drills and air to cool. Good luck!
  25. #19
    May 2017
    Minnesota
    1,741
    2255
    1153
    Definitely contact multiple tool reps, and do sample parts to prove out their tools and parameters before chewing into the real part. You don't want to have to deburr that backside too much.
  26. #20
    Jun 2012
    Michigan
    5,797
    5488
    3701
    Easy peasy, get a diamond coated drill. a GOOD one.
    In fact you're probably going to need 3-4 of them if I had to venture a guess depending on your speeds/feeds.
