Don Davis 87
- Mar 7, 2014
- Houston, TX
I have been making progress getting my used machine back together, now I'm finding new and exciting problems that I can't figure out. My machine has a Fanuc 18i control, as it is I can not override my rapid traverse movements, I definitely need to find out how to change that, the potentiometer works for 'Feed" moves but my rapids are too fast, I'd like to be able to override them so I can get through a setup without having a heart attack.
Also I have a second question,
I want to change from Metric to Inch, I'd like to set Inch as the default, when I try to change the on or off in the settings, I get a red flashing error that says 'WRONG MODE" and I haven't been able to get around that. If you guys can help a brother out, it would be greatly appreciated. Don
