Don Davis 87
- Mar 7, 2014
- Houston, TX
I’m trying to find out how to set the Z axis tool changer height. I bought the machine used without a manual. I would also like to buy a manual if I anyone has one. Thanks
I think you need to be more specific about the control, like model # and what exactly you mean by setting the tool changer height. This normally won't change unless someone changes it. But, basically, on a Fanuc, the Z axis tool change height is set in the 2nd reference position (G30). At least on all of the Fanucs I have run. I work for Doosan and all of our machines are set about 3MM below home position. (G28).
I've done this what seems like thousands of times on a 2007 with 21m. I believe the parameter your looking for is actually 1815. There is a value for all 3 axis. They should all be 1 when your finished.
https://www.fadalcnc.com/media/pdf/FANUC_Zero_Return_Procedure.pdf
If you need more help let me know and I'll walk you through the procedure.
Notice
