The title explains my issue for the most part. Using Fanuc control system.
N3(6.0mm dia x 90 spot face)
M69;
M303 G54;
G0T2016;
G361B-90.D0;
G43H216.;
T2029;
G98 G17 M45;
G28H0.;
G0C0.0;
M68;
G49;
G69.1;
M594;
M369;
B-80.;
M368;
M595;
G43H216.;
G68.1 X111.391 Y0.0 Z-149.158 I0 J1 K0 R10.0;
G97 S1700 M13;
X50.878 Y0.0 Z24.486
M484
X0.0 Z20.0
G83 Z-5.0 R-18.0 F60.;
This is the beginning of my programme. The hole is 6.5 inches from the backface of the job and at an incline of 10 degrees. The hole is 0.378” down from a diameter of 5.13”. Position of hole by calculations should be 4.374”(Diameter). My issue is that the drill goes around 17.5mm further below the X0.0 resulting in the hole being out of position.
Thanks for any help in advance my post is probably extremely vague.
M69;
M303 G54;
G0T2016;
G361B-90.D0;
G43H216.;
T2029;
G98 G17 M45;
G28H0.;
G0C0.0;
M68;
G49;
G69.1;
M594;
M369;
B-80.;
M368;
M595;
G43H216.;
G97 S1700 M13;
M484
X0.0 Z20.0
