gundog
Hot Rolled
- May 31, 2004
- Southwest Washington USA
You may have read my other posts about a Haas mill there is a company close by that has a lightly used Sharp Industries SVL-2416SE-M 04-14 date. I am trying to get more info on it and I may be able to go see it tomorrow. This is outside of what I was looking for but for the price I can get it for I maybe able to purchase a 3Ø converter and move it for less than buying the Haas TM-1P. It has a Siemens 828D control.
I know nobody knows the condition of this machine over the net but is this a decent machine? I will be machining 6061 T6 for my own business. Is the Siemens 828D control a good control?
Part of the reason I was going with the Haas was they offered training on their control. My experience is with running a CNC Router using Vectric software for CAD & CAM. My bed mill I program at the control. I have started trying to learn Fusion 360 but when I was talking to the Haas salesman ( I know he is a salesman) he asked if my CAD/CAM program had a Haas post possessor and it does it also has a PP for the Siemens 840D but I don't show one for the 828D.
I am proficient with my current CAD/CAM program so the salesman said I could use canned tapping cycles for tapping my CAD/CAM program does not support tapping because it was designed for CNC routers designed more for sign and cabinet guys. I have been using this program for 10 years so I really don't want to change unless I have to.
I am not sure this would be the right machine for me but my hunch is it is a better machine than the Haas TM-1P but whether it is better for my use is what I am trying to decide. It is a ton faster and probably more accurate but maybe more difficult for me to learn and use than the Haas.
This is the info I got from phase perfect I am not sure which converter I would need yet because I don't have the load info until I go see the machine.
Below you will find some specs and pricing for the phase converter for your application: (I cut out the pricing info.)
The PT330 digital phase converter will handle 36 amps of continuous load and 150 amps for four seconds of momentary load. Our converters provide balanced three phase power in the delta form within 1%. The converter is 97% efficient this model uses about 100W per hour on standby. The converter output voltage will match the input. The running volume is about 70db about conversation level
This one needs a 70 amp 240 volt service.
The PT355 digital phase converter will handle 64 amps of continuous load and 280 amps for four seconds of momentary load. Our converters provide balanced three phase power in the delta form within 1%. The converter is 97% efficient this model uses about 280W per hour on standby. The converter output voltage will match the input. The running volume is about 70db which is about conversation level.
This one needs a 125 amp 240 volt service.
