Hey, so this is my first post on here, this might not be the best section for this question.
Also somewhat new to machining.
So I'm working on a part that has four .251 +/-.0005 with .001 true pos. Im cutting them with the part attached firmly to a spud in a ddr rotary in a mori seiki dv. I have a .234 drilling the thru hole, as there are two holes on one face and the other 2 mirror them on the opposite face. The .2505 reamer is cutting to size at the top and the bottom at S550 feeding 4. Though it is tapering a few tenths from top to bottom which is throwing off on the cmm.
Basically would leaving .0085 per side from a letter A drill for a .2505 reamer cause it to taper smaller from top to bottom? or should I bring in a letter C Drill to lighten the load?
