3 o'clock position
petroff
Dec 17, 2019
Hello guys,
I urgently need your help please.
I have one lathe with Duplomatic turret that have loosed the tool reference point and now the live tools cannot work.
In order for the live tools to work the so called "mechanical zero position" black dot on the image bellow must be at 3 o'clock position.
Right now it is on something like 1:30 o'clock.
In the manual the instruction is to fiddle with parameter 1850 in order to do that but I am not sure how to do it.
I greatly will appreciate any help.
Robert
Am I to understand that this black dot is on the drive shaft, and not the turret top plate?
You are trying to index the drive shaft a wee bit?
I don't know your machine or turret, but 1850 is the same as any other app.
Settings
Parameter Write Enable
System
1850 search (or just page down)
edit the value
RESET
Then index the turret or whatever it is that you need to doo to make the drive shaft locate.
Note the amount moved and direction, edit and try again.
I don't think that you would need to reboot between edits, but wouldn't rule it out.
Reset the PWE to 0 when done.
I would have expected this to be a 4077 parameter, but ....
Think Snow Eh!
Ox
