Bigbore050
- Apr 4, 2016
Curious if others have accomplished something similar and how it went.
Part is a manifold so straightness isn't critical but unfortunately the part quantity didn't justify buying high dollar tooling so I'm stuck with your standard HSS twist drill. All holes are blind depths.
My hole list and strategy so far:
-7/8 x 18" deep
Pilot with 7/8 CAM Drill 4.5" deep then drill to depth with HSS.
-3/4 x 12.5" deep
Pilot with 3/4 CAM Drill 2.5" deep then drill to depth with HSS.
-5/8 x 18" deep
Helix 5/8 pilot 1.25" deep, Bottom out HSS jobber 4" deep and take to depth with long HSS.
1/2 x 5.5" deep
Plung 1/2 pilot 1.25" deep and drill to depth with HSS, Not to worried with this one.
3/8 x 14" deep
Plung 3/8 pilot 1.0" deep, bottom out 3/8 ext length HSS drill 7" deep, then take to depth.
Will be holding all the drills in either ER32 or ER40 CAT50 holders and turning them with a 630mm CNC Horizontal.
I am slightly worried with how well the 3/8 and 5/8 holes will go. Anyone have any tips or suggestions for the feeds, speeds, and pecks on these long drills?
-7/8 x 18" deep
-3/4 x 12.5" deep
-5/8 x 18" deep
1/2 x 5.5" deep
3/8 x 14" deep
