vmipacman
Cast Iron
- Nov 21, 2014
- Virginia, USA
Is a 40 taper 15K spindle on a bridge mill silly for a job shop environment?
Should I steer clear of that even if the deal is good?
First choice is a 50 taper gearbox spindle, but a 40 is currently available in the size machine I cam looking at, (used).
I admit I have never reached the max limitations of my CT40 VMC, but I might not even know it if I had...
I am usually not trying to reduce time or push things hard though.
I expect to be cutting some AR steels, Aluminum 7075, stainless, and maybe a TI part in a blue moon.
I worry about not having enough torque. I have never come close to running out on my 15HP VMC, but this is big machine to move and then find its under powered. Big tapped holes I can threadmill instead I guess.
This is billed as a High Speed variant of the standard CT50, so can I make up for the small spindle by employing HSM tactics across the board?
Thanks!
Thanks!
