garychipmaker
Cast Iron
- Dec 2, 2005
- ia
Hi I'm replacing the thrust bearings and seals for the Y axis ballscrew. the bearing block isn't doweled to the frame so how do you check the alignment when bolting the ballscrew nut to the saddle. Also I am eliminating the chiller connections to the ballscrew. And is there supposed to be air leaking from the spindle when spindle is running. I know it has an air blast when doing a tool change. Thanks again for the help.
