4020 Fadal how do you align the Y axis thrust bearing block to the saddle.
Results 1 to 10 of 10
    Dec 2005
    Iowa
    225
    20
    Default 4020 Fadal how do you align the Y axis thrust bearing block to the saddle.
    Hi I'm replacing the thrust bearings and seals for the Y axis ballscrew. the bearing block isn't doweled to the frame so how do you check the alignment when bolting the ballscrew nut to the saddle. Also I am eliminating the chiller connections to the ballscrew. And is there supposed to be air leaking from the spindle when spindle is running. I know it has an air blast when doing a tool change. Thanks again for the help.
    Sep 2008
    1,715
    1141
    988
    Quote Originally Posted by garychipmaker View Post
    Bring the table all the way to the back, so the ball nut is very close to the bearing block. That's probably the best way of aligning the thrust bearing.
    Do you have an air/oil lubricated spindle? That might explain the air leak
    Sep 2014
    Georgia
    515
    7
    84
    My spindles all “leal air” they push air through for the air purge to keep coolant and chips out.
    Dec 2005
    Iowa
    225
    20
    That's what I planned to do. It doesn't leave alot of room to tighten the bolts. And I thought maybe it was normal to have air at the spindle just didn't know. Thanks for the help guys
    Jan 2003
    354
    47
    94
    Yes, just make sure its free with table all the way back. The guys that sold me thrust bearings said to tighten bolts finger tight and move machine through its travel. Hopefully it will self align. Might be wishful thinking but cant hurt.
    The air through spindle is normal. I put a regulator on that line and dialed it back a little. Seemed a little excessive. Its just to keep coolant out, my machine has grease pack spindle, not air/oil.
  6. Likes macds liked this post
    Jul 2008
    Milverton, Ontario, Canada
    642
    176
    287
    From my experience, it all depends on who built the spindle.
    I have, what I would consider, a high quality rebuild that doesnt piss much air.
    I also have a brand new China spindle from one of the "Fadal" companies. It chews through air like a fat kid after smarties.
    Its also noisy, and runs out.
    Guess thats what you get for $3200 Canadian micro bucks and installing yourself
    Jan 2003
    354
    47
    94
    Quote Originally Posted by macds View Post
    Why not share who you got it from and save us the grief down the road...
  9. #8
    Dec 2015
    Connecticut
    1,003
    23
    315
    Quote Originally Posted by mmurray70 View Post
    This- I just bought a Fadal because parts are cheap and the replacement spindles can be had for $3500. I’d like to know which to avoid (or at least find out if this was a unique event)
  10. #9
    Jul 2008
    642
    176
    287
    I'll refrain from naming names, as I have had good service from them (for the most part).
    Was purchased as a reman, but was clearly brand new. Also had either Chinese or Taiwanese qc "tags" in the packaging.
    Looked good, so I tucked it away for a while until I needed it.
    Located in Idaho
    Should have just bought a new one from Dan @ ITS
  11. #10
    Dec 2005
    Iowa
    225
    20
    Located in Idaho
    My spindle is grease packed. Y axis is back together and running much quieter
