4th axis position on table-Fadal
Page 1 of 2 12 LastLast
Results 1 to 20 of 21
    Dec 2015
    Connecticut
    1,387
    32
    469
    Default 4th axis position on table-Fadal
    I fussed around aligning the new to me 4th axis on my Fadal, setting the offset and then realized the servo would come blowing through the door glass on max Y positive. I have about another .250” of +Y when the end of the servo hits the door window.
    I tried moving the axis to the rear slot but it hits the Z ways with minus .3” travel left.
    So... I either need to move my cold start or remember to open the door
    Anyone see this before. My Y axis CS position indicator does seem to be maxed out to the front, so there is probably a .250 adjustment.
    Any issue with moving the cold start 1/4”?
    Dec 2015
    Connecticut
    1,387
    32
    469
    I should mention I replaced the Y screw a while back, I don’t believe I had to move the cold start indicator, I had marked the screw coupler and tried to match the old and new screw ball nut positions when I coupled the motor back up.
    Maybe I can pull the motor and rotate the screw one or two turns( I don’t recall the pitch)
    Feb 2005
    9,704
    16509
    11854
    Just don't go to max Y+.
    I wouldn't mess around with trying to move your cold start position.
    That could just get you into trouble and end up with a blown driver board.
    Dec 2015
    Connecticut
    1,387
    32
    469
    I think I’ll just leave it as is , thanks for the reply
    Oct 2009
    Oregon
    6,165
    6599
    3491
    Nothing to do with Fadal specifically, but I always use a subplate and cantilever the 4th off the table. I like to put the face of the indexer at max/min X travel so I don't waste any travel, but I can mill anything I bolt to the face.
    Subplate lets you position it wherever you want in Y so you can center it.
    A friend has a nice Mori vertical with a 4th that hits the enclosure in one place. I have gotten used to it, but I still hate it. Several oh shit moments where I stopped it just in time.
  6. Likes mhajicek liked this post
    Dec 2015
    Connecticut
    1,387
    32
    469
    I do want to eventually hang the 4th over the rightX cover. I had a sub plate on the mill, but kept having to pull it off and re oil to keep corrosion at bay, it’s large enough to gain 6” of X travel
    May 2002
    South Central PA
    14,613
    2842
    4351
    Is there a limit switch that can be moved to keep it from hitting?
  9. #8
    Dec 2015
    Connecticut
    1,387
    32
    469
    Quote Originally Posted by Mud View Post
    Good idea, but no limit switches, you cold start the machine on index marks so the control has a starting reference and then the control just counts ball screw turns to get to the limits
  10. #9
    Jan 2003
    612
    134
    198
    The window should flex 0.250" Might as well get used to looking for crashes like that. Never ending with the 4th axis on table. It will always be in the way, tool holders will always want to hit jaws, coolant nozzles getting moved etc etc. Need to watch everything way closer then with 3 axis.
    What size Fadal is that? I have a 4020 and thinking about adding a smaller one too.
    Really sucks the way they have the whole cold start thing rigged up. Wish they would of came with proper home/limit switches like every other machine in the world.
  11. #10
    Oct 2014
    CANADA
    Ontario
    1,642
    1288
    1400
    Is this a DC servo machine? If so then I believe rotating the resolver relative to the servo will move the cold start position up to 1 thread pitch of the screw, not sure if that will be enough to give you clearance though!
    I would second the recommendation for a sub-plate! Seems a shame to waste so much X travel!
  12. #11
    Feb 2005
    9,704
    16509
    11854
    Quote Originally Posted by mmurray70 View Post
    What is cool though, is that the only machine I've never had a limit switch problem with, was a Fadal..
    Unless you count the tool changer.
    One more thing to break, one more thing to fix, and when it was new, one less thing you(they) had to pay for.
    On a 4020, you have plenty of room(Y axis) with a vh65. I'm guessing this is a 3016.
  13. Likes triumph406 liked this post
  14. #12
    Dec 2015
    Connecticut
    1,387
    32
    469
    DC control VMC 20
  15. #13
    Nov 2008
    California, USA
    86
    8
    17
    Not sure how ambitious you are but this is how I dealt with the same problem with a VH65 on a 3016. Nice to be able to move the 4th out of the way, as well as get some X back. You could make something similar offset in Y without a subplate.
  16. Likes Mud liked this post
  17. #14
    Dec 2015
    Connecticut
    1,387
    32
    469
    Thanks for the reply
    I can’t really make out the second pic, does the 4th mount to a dovetail base that slides in X (adjustable?)
  18. #15
    Nov 2008
    California, USA
    86
    8
    17
    Yes, sorry for the confusion, you got it right. The second picture is the back of the 4th axis, looking in from the right side of the machine. I have a collet closer hanging out the back of the 4th, so the limit on moving it x+ off the table is when it hits the right hand window. I basically get the entire table when it is "parked." Hasn't been off the machine in years (taking the VH65 in and out, and messing with connectors and the control is a PITA.)
  19. #16
    Dec 2015
    Connecticut
    1,387
    32
    469
    That’s pretty cool, thx
  20. #17
    Nov 2004
    RC, CA
    2,196
    228
    473
    Leave the CS in the center, and set the home position at 7.5. Easy to change back to 8 if you want the table closer without it. Just need to remember.
  21. #18
    May 2017
    Minnesota
    1,894
    2538
    1294
    Use steel for your subplate so you don't get galvanic corrosion.
  22. #19
    Jan 2016
    183
    29
    94
    Quote Originally Posted by mhajicek View Post
    Anodizing should also work, I think? (I remember anodizing being electrically insulating.) Probably better to be hard anodized so it's a little more resistant to scratching when the subplate gets mounted.
  23. #20
    Oct 2009
    Oregon
    6,165
    6599
    3491
    Quote Originally Posted by trochoidalpath View Post
    Type 3 is great, but the trick is it adds about .0015" to .002" to all surfaces.
    I have been using Slide no rust to stop the corrosion under aluminum subplates and it seems to work.
