Pete Deal
Titanium
- Apr 10, 2007
- Morgantown, WV
When I got my Brother Tapping center it came with a 4th axis. It is a Yuasa SUDX 170. I jogged it around to see that it worked but took it off because I did not need it at the time. This was a few years ago. I would like to reinstall it so I figured I ought to open it up to see what it looked like inside. Not good- nasty smelling something came out that looked more like rotten water than oil. I got it all apart and cleaned up and amazingly nothing really looks damaged. The bearings look good, worm looks good, etc. The only thing that does not look too good is the brake cylinder, which is sort of a big disk in there. I think it will be ok though.
Is this common? My guess is that it must be. At this point I am going clean it up and put it back together, try to seal it as best i can, and check/change the oil frequently. It has a stupid little 6mm bolt for an oil drain. I may drill and tap it 1/8 or 1/4 npt and to put a decent drain on it so it is possible to drain the oil without it all winding up in the coolant pan.
Also, the way the thing was wired in it had about 30' of sealtight like conduit with the cables in it that was coiled up on the side of the machine and wired into the control cabinet. I bought an Amphenol connector with about 30 pins and I think 6 larger pins. I am planning on cutting the cables, shortening, and put this in to clean the installation up some. There are power signals for the servo motor, which I figured I would put on the larger pins, a few switch/solenoid connections, and the encoder signals.
