I'm thinking of automating our 5 axis machine. I'd like to do something simple like how a fms system works with pallets on a horizontal. I was thinking of using a Schunk Vero-S unit to clamp on the machine with M codes. Then building my own pallets that the robot would load and unload. On the pallets would be various different fixtures/workholding but the pallets would all be the same. The robot grippers would never change, and the programming for the robot wouldn't change either.
I saw a few prepackaged systems and like the simplicity. Yamazen's Flex M system looks promising.
FLEX Robotic Automation System | Compact Machining Center - Yamazen
Erowa also has a few prepackaged systems and they seem to have a good reputation.
Robot Systems - EROWA AG
I've also see the versabuilt system, but I don't think their system that uses softjaws as grippers and workholding would work the best for me.
VersaBuilt | Home
Also what other systems besides the Schunk Vero-S are out there and a good fit for this type of setup? I already have a Vero-S clamping module that I was planning to use, but there might be something better for this application that I don't know about.
The prepackaged systems look like the easiest way to step into a system like this. This would be our first robot in the shop. My goals is to have as many pallets as possible in the system, so I can run overnight. I also need the pallets to be relatively inexpensive and I'd like to use as little floor space as possible. So will a prepackaged solution be the best or a custom integration?
Thanks in advance!
VersaBuilt | Home
Thanks in advance!
