Hello,
I was hoping for a quick sanity check. I have a part that I would like to produce, and my goal is to determine if the fixturing I am proposing would be sufficient.
Quick facts:
* Haas VF4-SS
* 4th Axis Haas HRT-160 with 5th Axis Rock Lock system already installed
* Cutting 303 Stainless Steel
* Flood Coolant
* 1.8x.75x.75 parts oriented as shown below.
My plan is to use my 4th Axis (HRT-160) that already is set up for the 52mm 5th Axis RockLock system. I need to face each side of the part with a 2" Shell Mill 0.015 deep and drill a couple of 1/8", holes, and mill approx a .120" Chamfer, as well as a couple other little things. Nothing too heavy.
My question is will this vice be sufficient for reliably holding my workpiece? In the future I will most certainly want to mill similar items and would possibly taking much more aggressive cuts.
I would prefer to stay inside the 5th axis eco-system, since my rotary table is outfitted with the 52mm Rock Lock fixture, and all of my other fixtures just bolt right up.
Will this vice hold on to 303 stainless reliably? What is the most aggressive I could expect to mill with a setup like this?
R52-V75100X - 5th Axis
Thanks!
Alex
Quick facts:
* Haas VF4-SS
* Flood Coolant
Thanks!
Alex
