Hi guys,
We've some shaft type jobs which have their 1st setup done, 2nd setup requires part to be faced, put a chamfer in bore to help tailstock revolving centre support.
Problem is, I don't have programmable tailstock body on all lathes. Need some tool which can quickly chamfer the bore before tailstock quill can actuate ... Can't let a boring bar do it since tailstock is quite near and usually quill stroke is short.
Maybe a tcmt style tool ? To be clamped in 25x25 OD turning tool spot ?
Chamfers are usually small, upto 2x60° max. Bore dia 14mm & upwards.
Sent from my XT1033 using Tapatalk
