rokstarr999
- Feb 7, 2014
- Sonoma County, USA
I'm looking for some advice on machining these grooves. I programmed it to rough out the groove with a .03 ball mill and then finish it with a 2FL .25" Dia 60 Deg chamfer tool. The tool has around a .015" flat at the tip and I'm thinking its just going to break at the tip. Material is 416 SST. The groove comes to a sharp point in the model. I think I can get away with the .015 at the tip. I have 4 of these to do. 2" wide x 9" long/ 34 grooves per part at .121" deep. Whats the proper way to make a groove like this?
Thank you.
Thank you.
