Drilling some parts using a sumitomo smd carbide tipped 8xD drill. Holes start on location, but then exit any where from .005 to .025 off center. material is 1020 plate, hole is thru, 4 inches deep. Part is held rigid in vise. Here are the details.
hole is .656 diam.
50 taper Horizontal HMC
side lock holder
.001-.0015 run out at drill tip
1000 psi thru coolant
Ive ran every where from 280 sfm to 450sfm
.006 to .012 IPR
Ive tried pecking
Ive added a spot using a larger smd drill with the same tip geometery
I called sumitomo, they were very helpful, we tried some different parameters, and then they even sent me a different body and tip profile to try ( same style body, just out of a different lot)
Holes are getting better, but still inconsistent, are .005 to .015 off.
chips are beautiful, 6 and 9s
Im told I do not need a pilot hole for this length drill (but???)
Short from buying another 3xD drill and tip to drill a short pilot hole, do any of you guys have any other suggestions??? Or is it just the nature of the beast in this cheaper material?
I could live with .005 off, but I need it to be consistent, not .005, then .01, then .012 etc. etc.
Ive had great luck with these drills in 5xD in 4340 and 4140.
hole is .656 diam.
side lock holder
.006 to .012 IPR
Ive tried pecking
