358Mustang
Cast Iron
- Apr 13, 2010
- Bay area
My machine will consistently cut an out of round part somewhere around .0008".
I went from a piece of 2" aluminum in a chuck , to swapping the collet nose with a piece of 1" stock hanging out about 2". I still get the same result...
I also noticed that it repeats with the position of the spindle, as in if I make a mark on the spindle where one part measures high, it will repeat this...
Finishes look pretty good, but I am wondering if it is a bearing or possibly something bent?? I indicated the spindle face before putting the collet nose on and it had about .0001" run out..
If I put the indicator on the side of the collet nose and pulled perpendicular with the machine I could get it to move about .0005" and spring back.. I would think it should be rock solid there
